[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#747 (master - 44ece6f)
Travis CI builds at travis-ci.org
Wed Dec 30 09:58:17 PST 2015
Build Update for GRASS-GIS/grass-ci
Build: #747
Status: Still Failing
Duration: 5 minutes and 34 seconds
Commit: 44ece6f (master)
Author: Václav Petráš
Message: v.in.pdal: LiDAR import tool based on PDAL [news]
Contains most of the v.in.lidar filters/selection tools.
Supports two advaced PDAL filters.
Tests for basic functonality.
Doesn't build topology. Stores
return, class and color info in predefined
layers as categories.
Tests and other .c files are similar
to those in v.in.lidar.
See also #2732 and r67293.
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@67436 15284696-431f-4ddb-bdfa-cd5b030d7da7
View the changeset: https://github.com/GRASS-GIS/grass-ci/compare/97fdf331df2c...44ece6fdd5fb
View the full build log and details: https://travis-ci.org/GRASS-GIS/grass-ci/builds/99472759
You can configure recipients for build notifications in your .travis.yml file. See https://docs.travis-ci.com/user/notifications
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20151230/923bdfba/attachment.html>
