[GRASS-dev] [GRASS GIS] #2732: Read lidar data as vector points using PDAL
trac at osgeo.org
Wed Dec 30 11:12:22 PST 2015
Reporter: wenzeslaus | Owner: wenzeslaus
Type: | Status: new
enhancement |
Priority: major | Milestone: 7.1.0
Component: Vector | Version: svn-trunk
Resolution: | Keywords: lidar, las, laz, v.in.lidar,
CPU: | v.in.pointcloud, v.in.pdal
Unspecified | Platform: Unspecified
Comment (by wenzeslaus):
First version now available in trunk. PDAL compilation support added in
r67293 and ''v.in.pdal'' in r67436. Configure GRASS with:
./configure ... --with-pdal="/path/to/pdal-config"
PDAL can be compiled with or without LAZ (LAZlib) support and PCL support,
so not all the functions may be available. If you compiled PDAL yourself
you need to do also:
export LD_LIBRARY_PATH="/path/to/pdal/install/lib:$LD_LIBRARY_PATH"
I decided that the name ''v.in.pdal'' will be best because there are some
PDAL-specific functions included. This includes also reprojection during
import. However, the name can be changed, `v.in.points` sounds good as
well.
The next steps are:
* add missing functions (implemented in GRASS) from libLAS-based
''v.in.lidar'' namely vector mask and count-based decimation
* add more [http://www.pdal.io/stages/#filters PDAL-based filters] (please
suggest!)
* implement ''r.in.pdal'' similar to ''r.in.lidar'' (also needs list of
filters to be implemented)
* implement ''!r3.in.pdal''
* implement ''v.out.pdal'' similar to ''v.out.lidar''
* move some of the common functions to `lib/lidar` (most of the common
functionality was already re-factored out from ''r.in.lidar'' and
''v.in.lidar'' and used in ''v.in.pdal'' and ''v.decimate''
Things like mask or various decimations have (or can have) GRASS
implementation and have PDAL implementation as well. It would make sense
to do these operations at the beginning and at the end of the import
process. If it would be at the beginning, only PDAL implementations can be
used.
Note also that there are still some unresolved issues related to PDAL
ability to handle large amounts of points although some solutions were
proposed on the PDAL mailing list.
Finally, note also that PDAL is a processing library, so it can be also
used in a separate module which would process vector points.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2732#comment:5>
