[GRASS-dev] [GRASS GIS] #2205: Unicode unequal comparison in location wizard when title contains non-ascii letters
trac at osgeo.org
Thu Dec 31 07:01:15 PST 2015
letters
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Resolution: fixed | Keywords:
CPU: Unspecified | Platform: Unspecified
Comment (by annakrat):
Replying to [comment:9 marisn]:
> Replying to [comment:8 hellik]:
> > so still an issue?
> Your test is not an indicator of THIS problem. As per Glynn's comment,
"āšņļ" will be a valid test only for Windows set to run with Baltic
locale, you most likely run Western Europe version thus the test text
should be: "äêíõû"
> As in one year nobody has cared to deal with encoding mess, closing this
as fixed in 7.1.0
I am not getting any error in trunk or releasebranch. When I specify new
location name the wizard correctly reports non-ascii characters and
doesn't allow me to continue. It's on my Ubuntu. Is there anything
specific to trigger the error?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2205#comment:10>
