[GRASS-dev] Compute mahalanobis distance using Scipy
Paulo van Breugel
p.vanbreugel at gmail.com
Sun Feb 1 06:18:07 PST 2015
On Fri, Jan 30, 2015 at 3:39 PM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Paulo van Breugel wrote:
> > I would like to compute a raster layer with for each raster cell the
> > mahalanobis distance to the centre of the environmental space formed by
> all
> > reference data points (raster cells). In R this can be done as explained
> > here [1].
> > . I would like to do this using python only (no dependency on R). I came
> up
> > with the following, which works, but is very slow. I guess this is
> because
> > it loops over every raster cell to compute the mahalanobis distance? Any
> > idea how this can be done faster (I am very new to python, so bear with
> me
> > if I am making stupid mistakes)
> The main speed-up will come from "inlining" distance.mahalanobis(),
> which is essentially:
> delta = u - v
> m = np.dot(np.dot(delta, VI), delta)
> return np.sqrt(m)
> np.dot(v, m) is equivalent to np.sum(v * m,axis=0), and np.dot(u,v) is
> equivalent to np.sum(u * v), so the second line above is equivalent to
> m = np.sum(np.sum(delta[:,None] * VI * delta[None,:], axis=-1),
> axis=-1)
Smart! I can follow the logic, but I am not sure how to solve the problem
below:
File "<stdin>", line 1, in <module>
ValueError: operands could not be broadcast together with shapes
(3,1,77,78) (3,3)
Which refers to the different dimensions of delta and VI?
> Thus, delta can be extended from a 1-D array to 3-D, changing the
> result from a scalar to a 2-D array. The calculation of stat_mah then
> becomes:
> VI = np.linalg.inv(covar)
> delta = dat_ref - stat_mean[:,None,None]
> m = np.sum(np.sum(delta[:,:,:,None] * delta[:,:,None,:] *
> VI[None,None,:,:],axis=-1),axis=-1)
> stat_mah = np.sqrt(m)
> This moves the loops from Python into C, which usually results in a
> significant speed increase.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150201/9ee88bf6/attachment-0001.html>
