[GRASS-dev] New wiki page summarising GRASS APIs
Moritz Lennert
mlennert at club.worldonline.be
Mon Feb 2 00:23:52 PST 2015
On 01/02/15 21:22, Vaclav Petras wrote:
> On Sun, Feb 1, 2015 at 2:26 PM, Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>> wrote:
> On 01/02/15 12:29, Glynn Clements wrote:
> Pietro wrote:
> import os
> os.system('g.region rast=elevation')
> and not subprocess:
> import subprocess
> subprocess.call('g.region rast=elevation', shell=True)
> # or
> subprocess.Popen('g.region rast=elevation', shell=True)
> Concerning the pygrass Module API, may be we can use the
> shortcut version:
> Using subprocess.call() with shell=True is no better than using
> os.system(). Both should be avoided at all costs.
> The grass.script module provides a number of convenience functions
> which use grass.script.make_command() to generate the command's
> argument list from the function's argument list. Also, they use a
> version of subprocess.Popen() which has been wrapped to deal
> with some
> of Windows' idiosyncrasies.
> Just to be clear: the example on this wiki page shows just that it
> is possible to call any GRASS module from any language that allows
> system calls. It then goes on to introduce the scripting API to show
> how that eases things on the script writer since she doesn't have to
> deal with any idiosyncrasies.
> But if this causes too much opposition I can take it out or at least
> put a big warning of likes of "Don't use this ! Example code only."
> I suggest to use Bash example instead of Python one because this is how
> it is actually (also) used.
Well, there's no real syntax for a GRASS module call from Bash, you just
do it, so the first example on the page can actually be considered a
Bash example...
> If some warning is needed, it probably applies to all, Bash, C system
> calls and Perl too.
Maybe I should just erase all examples, just leaving the information
that you can call GRASS modules via system calls if you know what you
are doing.
For now, I've added a warning that you should know what you are doing if
you want to use these calls.
> Do you consider a section for 3rd party APIs? Particularly I'm asking
> about spgrass in R (the same philosophy as grass.script for Python) and
> QGIS Processing (wrapper, limited functionality?, different philosophy).
Good idea. I just added a section linking to these two. I don't have
much time these days to add anything else on them. So anyone who does,
feel free.
Moritz
