[GRASS-dev] Compute mahalanobis distance using Scipy
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Feb 2 06:40:19 PST 2015
On Mon, Feb 2, 2015 at 1:38 PM, Glynn Clements <glynn at gclements.plus.com>
wrote:
> Paulo van Breugel wrote:
> > > The main speed-up will come from "inlining" distance.mahalanobis(),
> > > which is essentially:
> > > delta = u - v
> > > m = np.dot(np.dot(delta, VI), delta)
> > > return np.sqrt(m)
> > > np.dot(v, m) is equivalent to np.sum(v * m,axis=0), and np.dot(u,v) is
> > > equivalent to np.sum(u * v), so the second line above is equivalent to
> > > m = np.sum(np.sum(delta[:,None] * VI * delta[None,:], axis=-1),
> > > axis=-1)
> > Smart! I can follow the logic, but I am not sure how to solve the problem
> > below:
> > Traceback (most recent call last):
> > File "<stdin>", line 1, in <module>
> > ValueError: operands could not be broadcast together with shapes
> > (3,1,77,78) (3,3)
> > Which refers to the different dimensions of delta and VI?
> The first version of the code (which is quoted above) will only work
> with 1-D arrays. It's just a fairly direct translation of the existing
> distance.mahalanobis() function, given to explain how it can then be
> extened to 3-D arrays (i.e. a 2-D array of 1-D vectors).
> The second version:
> > > VI = np.linalg.inv(covar)
> > > delta = dat_ref - stat_mean[:,None,None]
> > > m = np.sum(np.sum(delta[:,:,:,None] * delta[:,:,None,:] *
> VI[None,None,:,:],axis=-1),axis=-1)
> > > stat_mah = np.sqrt(m)
> should work with delta being a 3-D array.
Yes, but when running the lines above, I am getting the same error message:
(3,77,78,78) (1,1,3,3)
>From what I can see from broadcasting rules, there is mismatch in the last
and fore-last dimensions of VI[None,None,:,:] compared to the other two?
delta[:,:,:,None].shape
(3, 77, 78, 1)
delta[:,:,None,:].shape
(3, 77, 1, 78)
VI[None,None,:,:].shape
(1, 1, 3, 3)
I am really have to get a better grasp of working with these arrays, but in
any case, after a bit trial and error, I came up with the following to
compute m.
m = np.sum(np.sum(delta[None,:,:,:] * VI[:,:,None,None],axis=1) * delta,
axis=0)
This does, in my limited testing, gives the same result as using the loop
with
pow(distance.mahalanobis(cell_ref, stat_mean, VI),2).
to be sure, does the above makes sense to you?
Paulo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150202/124af5bb/attachment.html>
