[GRASS-dev] New wiki page summarising GRASS APIs
Moritz Lennert mlennert at club.worldonline.be
Mon Feb 2 23:50:45 PST 2015
On 02/02/15 19:07, Glynn Clements wrote:
> Moritz Lennert wrote:
>>>> For now, I've added a warning that you should know what you are doing if
>>>> you want to use these calls.
>>> Why not just use suitable examples, e.g. using subprocess.Popen()
>>> (without shell=True), with the caveat that on Windows it won't work
>>> for scripts, only compiled executables.
>> But what exactly is the problem with using subprocess.call with
>> shell=True ?
> It requires you to construct the correct string. If the command string
> is a single literal string with all argument values consisting of
> alphanumerics plus "safe" punctuation (i.e. characters which have no
> meaning to any shell), that's simple enough.
> But if any of the arguments are variable and *could* contain
> characters which are meaningful to a shell, constructing the correct
> string (the one which results in the called program's argv[] having
> the intended values) isn't straightforward (and the exact rules vary
> between platforms).
> It's much simpler (and safer) to just remove the shell from equation
> altogether and pass the individual arguments directly, rather than
> trying to construct a string which, when deconstructed by the shell,
> will produce the correct result.
>> Security issues ? Difficulties in calling shell scripts ?
> Security would be a problem, but if you're dealing with potentially
> malicious input, it's the least of your problems compared to the rest
> of GRASS. Calling scripts on Windows is a different problem (setting
> shell=True "solves" one problem while introducing more).
>> AFAICT, it's just a wrapper around Popen.wait(), or ?
> subprocess.call() is a wrapper() around Popen() and Popen.wait().
> Exactly the same issue applies to Popen() itself (it applies to
> .call() *because* it applies to Popen() itself).
Ok, thanks for all the explanations.
>> I've now replaced this with:
>>    subprocess.Popen(['r.watershed', 'elevation=elevation',
>> 'threshold=10000', 'stream=raster_streams'])
>> or would it be better with .wait():
>>    import subprocess
>> 'threshold=10000', 'stream=raster_streams']).wait()
> subprocess.call() is fine. It's using shell=True which is the problem.
> For simple examples, I'd suggest using subprocess.call, and referring
> them to the python.org documentation for the (2.x) subprocess module
> for anything else.
Ok, I put .call back in.
>> And even though within GRASS Python it should always be Popen(), maybe
>> there are situations out there where calling a module via call() is
>> justifiable...
> Well, depending upon what you mean by "GRASS Python", it should
> arguably be grass.script.run_command() or similar.
> Even if the wiki page isn't the right place to introduce that, it's
> probably worth mentioning that it exists before users end up
> recreating the wheel (e.g. if they care about being able to run both
> executables and script and doing so on both Unix/MacOSX and Windows,
> they'll end up having to learn the same lessons we have).
This is what the warning before the system call examples says:
"Warning: In many cases, system calls such as these demand that you
really know what you are doing. If you want to program in Python, you
are encouraged to rather use the existing Python APIs explained below
instead of such system calls."
And then it goes on with:
"These system calls are easy to handle when no output is expected from
the GRASS module. When output needs to be collected then the programming
task already becomes a little harder unless you know what you are doing.
Equally, they can be tricky when introducing variable arguments and
special characters. It is for this reason that the Python GRASS
libraries where developed that are explained in the next section."
I hope this is explicit enough.
Again, the aim of this page is not to give a programming course, but
rather to show that you can program with and for GRASS in different way,
from single system calls to GRASS modules to full-fledged programming
with the C-API.
Moritz
