[GRASS-dev] [GRASS GIS] #2576: db.columns cannot find table created by v.overlay
GRASS GIS trac at osgeo.org
Tue Feb 3 03:43:54 PST 2015
 Reporter:  pertusus     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-releasebranch70
 Keywords:               |    Platform:  Linux
      Cpu:  Unspecified  |
Comment(by mmetz):
 Replying to [ticket:2576 pertusus]:
 > With svn 7.0.0 up-to-date (r64408). The table created by v.overlay can
 be queried by v.db.select, but db.columns does not find it:
 v.overlay ainput=uno atype=area alayer=1 binput=due btype=area blayer=1
 output=test_or operator=or olayer=1,0,0 --overwrite
 db.columns test_or
 WARNING: Table <test_or> not found in database
          <$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db> using driver
 <sqlite>
 The name of the table created by v.overlay is test_or_1, not test_or. The
 reason is that v.overlay might create several tables for the output.
 Please use v.db.connect -g first.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2576#comment:1>
