[GRASS-dev] [GRASS GIS] #2577: d.info: entire screen version frame
GRASS GIS trac at osgeo.org
Tue Feb 3 08:30:03 PST 2015
 Reporter:  martinl      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Display      |     Version:  svn-trunk
 Keywords:  d.info       |    Platform:  Unspecified
      Cpu:  Unspecified  |
 It seems that `d.info` reports wrong values when GRASS_RENDER_FRAME is
 defined, if I understand well `-r` should return (entire) screen rectangle
 and `-f` active frame rectangle.
 Example:
 export GRASS_RENDER_IMMEDIATE=cairo
 export GRASS_RENDER_WIDTH=600
 export GRASS_RENDER_HEIGHT=540
 No frames involved:
 d.info -r
 rectangle: 0.000000 600.000000 0.000000 540.000000
 d.info -f
 frame: 0.000000 600.000000 0.000000 540.000000
 Define frame:
 export GRASS_RENDER_FRAME=270,540,0,300
 OK:
 d.info -f
 frame: 0.000000 300.000000 270.000000 540.000000
 Here I would expect the entire screen:
 d.info -r
 rectangle: 0.000000 300.000000 270.000000 540.000000
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/2577>
