[GRASS-dev] [GRASS GIS] #2509: d.mon output overwrite
trac at osgeo.org
Tue Feb 3 13:30:03 PST 2015
Reporter: martinl | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Display | Version: unspecified
Keywords: d.mon | Platform: Unspecified
Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:24 glynn]:
> 2. The arguments are being concatenated into a string (without correct
quoting) then passed as a single argument. The output from G_recreate()
command may be sufficient for a human-readable description of the command,
but it's not suitable for execution. G_parser() needs to save argv so that
it can be retrieved, and D_open_driver() needs to pass the actual argv
using G_vspawn_ex().
Passing the arguments as actual individual arguments is what is used, e.g.
in Python:
python file.py arg1 arg2 arg3
python -c file.py arg1 arg2 arg3
python -m module arg1 arg2 arg3
Passing commands as one string is probably necessary in some cases (e.g.
when they are stored into a file or when a module would take more
different commands as input) but if it can be avoided, it should be
avoided I think.
Anyway, Martin, it seems that this will be quite an improvement if you are
heading where I think you are heading.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2509#comment:26>
