[GRASS-dev] [GRASS-user] temporary files of grass.script.array
Johannes Radinger
johannesradinger at gmail.com
Wed Feb 4 01:35:30 PST 2015
I just tested in trunk, and it works: The temporary file that is create
when assigning a raster to an python array is deleted once e.g.
the python session is closed again. So this would be a nice
thing also to have implemented in the next RC of GRASS7.
/johannes
On Tue, Feb 3, 2015 at 11:35 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Feb 3, 2015 at 4:23 PM, Glynn Clements <glynn at gclements.plus.com>
> wrote:
> > The temporary files were supposed to be deleted when the array object
> > was destroyed. However, this relied upon the ._close() method, which
> > is no longer used. r64426 (trunk) should fix this.
> Please let me know if that should be backported then.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150204/44a62c15/attachment.html>
