[GRASS-dev] [GRASS GIS] #2509: d.mon output overwrite
trac at osgeo.org
Wed Feb 4 05:43:01 PST 2015
Reporter: martinl | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Display | Version: unspecified
Keywords: d.mon | Platform: Unspecified
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:27 glynn]:
> So if you want to retain the existing semantics for MONITOR, all
references to it should be removed from the display library. Instead,
wxGUI would set GRASS_RENDER_COMMAND to refer to a program or script which
implements the MONITOR behaviour. Any future changes to the wxGUI monitor
mechanism would only affect wxGUI and its utility programs, not the
display systems.
it's not only about wxGUI. The reason for having (GRASS) variable MONITOR
is the module `d.mon` which allows to manage "file-based monitors" (like
cairo output) and also standalone wxGUI monitors. This feature is
requested by many of GRASS users, there is strong interest to have `d.mon`
in GRASS 7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2509#comment:28>
