[GRASS-dev] [GRASS GIS] #2509: d.mon output overwrite
trac at osgeo.org
Wed Feb 4 06:31:54 PST 2015
Reporter: martinl | Owner: martinl
Type: defect | Status: assigned
Priority: normal | Milestone: 7.0.0
Component: Display | Version: unspecified
Keywords: d.mon | Platform: Unspecified
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:30 glynn]:
> Replying to [comment:28 martinl]:
> > > So if you want to retain the existing semantics for MONITOR, all
references to it should be removed from the display library. Instead,
wxGUI would set GRASS_RENDER_COMMAND to refer to a program or script which
implements the MONITOR behaviour. Any future changes to the wxGUI monitor
mechanism would only affect wxGUI and its utility programs, not the
display systems.
> > it's not only about wxGUI. The reason for having (GRASS) variable
MONITOR is the module `d.mon` which allows to manage "file-based monitors"
(like cairo output) and also standalone wxGUI monitors. This feature is
requested by many of GRASS users, there is strong interest to have `d.mon`
in GRASS 7.
> Now that you mentioned that, I decided to take a look at d.mon.
> I must have missed the discussion about the implementation of this. Can
you tell me where to find it?
display/d.mon ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2509#comment:31>
