[GRASS-dev] [GRASS GIS] #2337: t.list hangs on newly created temporal DB
trac at osgeo.org
Thu Feb 5 04:11:57 PST 2015
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Temporal | Version: svn-trunk
Keywords: t.list,t.create | Platform: Linux
Cpu: Unspecified |
Changes (by neteler):
* keywords: t.list => t.list,t.create
Comment:
Reporting again with hanging t.create: We run current GRASS 7.1.svn in the
office and mount /grassdata via NFS3 from our cluster frontend machine.
With strace we got an idea where the problem is. Note that the user is
not operating in the mapset "lexem_matteo" cited below nor is it in
the mapset search path but it simply exists in the same location which
we share among our group:
GRASS 7.1.svn (eu_laea): >
strace t.create output=Tdaily_modis_hants type=strds semantictype=mean
temporaltype=absolute title="daily temperature from Mod lst hants"
description="daily T from hants on modis lst"
getuid() = 10014
stat("/grassdata/eu_laea/lexem_matteo", {st_mode=S_IFDIR|0755,
st_size=4096, ...}) = 0
getuid() = 10014
getuid() = 10014
getuid() = 10014
getuid() = 10014
getuid() = 10014
^CTraceback (most recent call last):
File "/usr/local/grass-7.1.svn/scripts/t.create", line 84, in <module>
main()
File "/usr/local/grass-7.1.svn/scripts/t.create", line 77, in main
tgis.init()
File "/usr/local/grass-7.1.svn/etc/python/grass/temporal/core.py",
line 593, in init
Process Process-1:
Process Process-2:
File "/usr/lib64/python2.6/multiprocessing/process.py", line 232, in
_bootstrap
_bootstrap
self.run()
File "/usr/lib64/python2.6/multiprocessing/process.py", line 88, in run
self._target(*self._args, **self._kwargs)
File
"/usr/local/grass-7.1.svn/etc/python/grass/pygrass/messages/__init__.py",
line 65, in message_server
self.run()
File
"/usr/local/grass-7.1.svn/etc/python/grass/temporal/c_libraries_interface.py",
line 769, in c_library_server
conn.poll(None)
KeyboardInterrupt
dbif = SQLDatabaseInterfaceConnection()
line 839, in __init__
self.tgis_mapsets = get_available_temporal_mapsets()
line 439, in get_available_temporal_mapsets
mapsets = c_library_interface.available_mapsets()
File
line 1220, in available_mapsets
return self.client_conn.recv()
KeyboardInterrupt
functions[data[0]](lock, conn, data)
File
line 159, in _available_mapsets
if libgis.G_mapset_permissions(mapset) > 0:
KeyboardInterrupt
The ID of the actual user is 10014.
PROBLEM:
The issue happens in line 142
lib/python/temporal/c_libraries_interface.py
function def _available_mapsets(lock, conn, data):
where a while loop is used. The issue is apparently caused by the fact
that in our current cluster setup, after reinstallation, the NFS
daemon doesn't properly map the user ID's to the local workstation in
the office where not all users are existing. While we have to fix
this, it should not lead to an endless loop:
Apparently libgis.G_mapset_permissions() does not behave properly for
this NFS case. It should be able to leave the while loop rather than
getting stuck there.
# example for one of our NFS mounted directories as seen on the office
workstation:
ls -la /grassdata/eu_laea/lexem_matteo
total 312
drwxr-xr-x 13 10012 gis 4096 Jan 17 16:09 .
drwxrwxr-x 125 1338 gis 16384 Feb 3 18:35 ..
-rw------- 1 10012 gis 122050 Jan 1 18:26 .bash_history
-rw-r--r-- 1 10012 gis 1949 Jan 17 16:09 .bashrc
drwxr-xr-x 2 10012 gis 20480 Dec 27 14:22 cats
drwxr-xr-x 2 10012 gis 20480 Dec 27 14:22 cell
drwxr-xr-x 2 10012 gis 20480 Dec 27 14:22 cellhd
drwxr-xr-x 19 10012 gis 20480 Dec 27 14:22 cell_misc
--> user IDs not transmitted, our problem, but
libgis.G_mapset_permissions() doesn't deal with it properly (or
def_available_mapsets()).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2337#comment:4>
