[GRASS-dev] Howto use a Python function as error handler in libgis
Sören Gebbert
soerengebbert at googlemail.com
Fri Feb 6 14:41:30 PST 2015
Dear developers,
i am trying to register a Python function as error handler callback
using ctypes in libgis.
I use this code in the temporal framework:
def error_handler(data):
pass
CALLBACK = CFUNCTYPE(None, c_void_p)
CALLBACK.restype = None
CALLBACK.argtypes = c_void_p
cerror_handler = CALLBACK(error_handler)
libgis.G_add_error_handler(cerror_handler, POINTER(None))
Unfortunately i get this error:
File "/usr/lib/python2.7/multiprocessing/process.py", line 258, in _bootstrap
self.run()
File "/usr/lib/python2.7/multiprocessing/process.py", line 114, in run
self._target(*self._args, **self._kwargs)
File "/home/soeren/src/grass7.1/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/temporal/c_libraries_interface.py",
line 759, in c_library_server
ArgumentError: argument 1: <type 'exceptions.TypeError'>: expected
CFunctionType instance instead of CFunctionType
Does anyone know what the correct way is to register a Python function
as error handler in libgis?
Any help is highly welcome.
Best regards
Soeren
