[GRASS-dev] splash screen image comes up too late [Re: Planning GRASS GIS 7.0.0RC2]
Moritz Lennert mlennert at club.worldonline.be
Sat Feb 7 01:01:09 PST 2015
On 07/02/15 09:44, Martin Landa wrote:
> Hi,
> 2015-02-06 17:32 GMT+01:00 Moritz Lennert <mlennert at club.worldonline.be>:
>> When I look at the example splashscreen code at [1], I see that the splash
>> screen is defined as a separate class that is called from the wxApp's OnInit
>> function and then calls the main GUI from its OnExit function. Using the
>> example code here with the 400K version of the splash screen works
>> perfectly.
>> I'm not familiar enough with wxPython and the wxGUI to adapt this quickly,
>> but maybe this could inspire some of the wx gurus...
> I modified wxgui.py in trunk (r64489) accordingly. Testing highly welcome.
The splash screen now looks good, but I get:
   File
"/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-unknown-linux-gnu/gui/wxpython/wxgui.py",
line 87, in OnExit
     workspace = self.workspaceFile)
   File
"/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-unknown-linux-gnu/gui/wxpython/lmgr/frame.py",
line 122, in __init__
     self._moduleTreeBuilder = LayerManagerModuleTree()
   File
"/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-unknown-linux-gnu/gui/wxpython/lmgr/menudata.py",
line 66, in __init__
     MenuTreeModelBuilder.__init__(self, fallback)
   File
"/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-unknown-linux-gnu/gui/wxpython/core/menutree.py",
     expAddons(xmlTree)
   File
"/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-unknown-linux-gnu/gui/wxpython/core/toolboxes.py",
line 274, in expandAddons
     _expandRuntimeModules(root)
   File
line 515, in _expandRuntimeModules
     desc, keywords = _loadMetadata(name)
   File
line 541, in _loadMetadata
     task = gtask.parse_interface(module)
   File
"/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python/grass/script/task.py",
line 509, in parse_interface
     tree = etree.fromstring(get_interface_description(name))
   File
line 493, in get_interface_description
     "\n\nDetails: %(det)s") % {'cmd': cmd, 'det': e}
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 32:
ordinal not in range(128)
And the GUI does not appear.
Don't know if this is related to your fix.
Moritz
