[GRASS-dev] splash screen image comes up too late [Re: Planning GRASS GIS 7.0.0RC2]
Martin Landa landa.martin at gmail.com
Sat Feb 7 01:12:34 PST 2015
2015-02-06 19:56 GMT+01:00 Anna Petrášová <kratochanna at gmail.com>:
> Although this example will work fine, it overlooks the main reason
> programmers add a splash screen; to give the user feedback while a program
> is loading.
this is right.
> It first displays splash screen for 1 second and then start to load the main
> frame. So this would basically make the gui start even longer.
> I don't have problems as you describe so it's difficult to test anything. I
Same here, I wonder if to go back to the previous version of splashscreen.
> still don'y understand, did you have the same problems with the old splash
> screen?
I also didn't understand that. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
