[GRASS-dev] [GRASS GIS] #2581: Fix Python ctypes conversion for stat64 struct on GNU/Hurd
trac at osgeo.org
Sun Feb 8 07:51:12 PST 2015
Reporter: sebastic | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python ctypes | Version: svn-releasebranch70
Keywords: | Platform: Unspecified
Cpu: x86-32 |
The Debian package build of GRASS 7.0.0RC1 on the hurd-i386 architecture
revealed some more issues.
The attached patch encloses the Python ternary expression in parenthesis
to fix an issue with the C to Python conversion of the stat & stat64
structs on GNU/Hurd.
The structs define the final member conditionally, for the {{{stat64}}}
structure this is:
#define _SPARE_SIZE ((sizeof (__fsid_t) == sizeof (int)) ? 9 : 8)
int st_spare[_SPARE_SIZE]; /* Room for future expansion. */
#undef _SPARE_SIZE
This gets converted by {{{ctypesgen}}} to:
('st_spare', c_int * (sizeof(__fsid_t) == sizeof(c_int)) and 9 or 8),
Which causes a {{{TypeError}}} for every Python script including the
generated gis.py:
TypeError: second item in _fields_ tuple (index 17) must be a C type
Enclosing the Python expression in parenthesis fixes the error:
('st_spare', c_int * ((sizeof(__fsid_t) == sizeof(c_int)) and 9 or 8)),
Since [https://pypi.python.org/pypi/ctypesgen ctypesgen] doesn't look
actively maintained upstream anymore, I'm forwarding this patch for
inclusion in GRASS only.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2581>
