[GRASS-dev] splash screen image comes up too late [Re: Planning GRASS GIS 7.0.0RC2]
Moritz Lennert
mlennert at club.worldonline.be
Mon Feb 9 07:00:31 PST 2015
On 09/02/15 15:32, Anna Petrášová wrote:
> On Mon, Feb 9, 2015 at 7:50 AM, Martin Landa <landa.martin at gmail.com
> <mailto:landa.martin at gmail.com>> wrote:
> Hi,
> 2015-02-09 9:37 GMT+01:00 Moritz Lennert
> <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>:
> > I agree, again especially if I'm the only one with this issue.
> > Don't change the startup logic with RC2. If this needs changing then this
> > should go into a point release.
> Absolutely agree.
> > FYI, however, here's a movie showing the three GUI startups in release64,
> > release70 and trunk, all three completely fresh checkouts and compiles:
> >http://tomahawk.ulb.ac.be/moritz/splash_screen.ogv
> BTW, it's quite visible here that wxGUI in trunk starts more slowly
> (related to the recent changes in wxgui.py) compared to GRASS 70.
> Perhaps we should go back to the previous version. I would suggest to
> move the GMFrame import after showing the splash screen (the diff is for
> release branch):
> --- wxgui.py(revision 64473)
> +++ wxgui.py(working copy)
> @@ -34,9 +34,7 @@
> except ImportError:
> SC = None
> -from lmgr.frame import GMFrame
> class GMApp(wx.App):
> def __init__(self, workspace = None):
> """ Main GUI class.
> @@ -79,6 +77,7 @@
> wx.Yield()
> # create and show main frame
> + from lmgr.frame import GMFrame
> mainframe = GMFrame(parent = None, id = wx.ID_ANY,
> workspace = self.workspaceFile)
> as a result on my computer, the splash screen is showed earlier. It
> probably won't effect the problem Moritz has, but it's worth trying.
It doesn't seem to make any difference here. I don't have the feeling
that the splash screen is shown any earlier, and the splash image still
only fills the splash screen at the same moment the GUI comes up.
> I
> also saw someone mentioning calling Refresh() and Update() on the splash
> screen after showing it. Then, there is a more complicated solution
> http://wiki.wxpython.org/SplashScreen%20While%20Loading.
This is via a fork. Am not informed enough to know what the difference
between that and threading is.
Moritz
