[GRASS-dev] splash screen image comes up too late [Re: Planning GRASS GIS 7.0.0RC2]
Moritz Lennert mlennert at club.worldonline.be
Mon Feb 9 07:10:08 PST 2015
On 09/02/15 15:47, Martin Landa wrote:
> Hi,
> 2015-02-09 15:32 GMT+01:00 Anna Petrášová <kratochanna at gmail.com>:
>> Perhaps we should go back  to the previous version. I would suggest to move
> agreed, done in r64527.
>> the GMFrame import after showing the splash screen (the diff is for release
>> branch):
> done in r64528.
>> as a result on my computer, the splash screen is showed earlier. It probably
>> won't effect the problem Moritz has, but it's worth trying. I also saw
> Moritz, does it any effect for you?
Well, now I have the same problem of a temporarily empty splash screen
again which was solved with your previous modification. And as mentioned
I don't really see any difference in speed for the arrival of that empty
splash screen.
Am I really the only one who sees this empty rectangle as a splash
screen for a little moment before the image fills it ???
Moritz
