[GRASS-dev] Building GRASS packages from tarball on Launchpad
Ivan Mincik
ivan.mincik at gmail.com
Tue Feb 10 08:51:02 PST 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 10.02.2015 09:34, Martin Landa wrote:
> Hi,
> 2015-02-10 2:27 GMT+01:00 Ivan Mincik <ivan.mincik at gmail.com>:
>> Sorry for late response, I have missed your emails somehow. Try
>> to install 'dpatch' package on your system.
> ops, you are right. Unfortunately the command now fails with:
> $ git-buildpackage --git-debian-branch=master
> --git-builder="debuild -S -sa" --git-ignore-new ... dpkg-source -b
> pkg-grass dpkg-source: info: using options from
> pkg-grass/debian/source/options:
> --extend-diff-ignore=(^|/)(config\.sub|config\.guess|mswindows/osgeo4w/grass.tmpl|config.log)$
dpkg-source: error: can't build with source format '3.0 (native)':
> native package version may not have a revision dpkg-buildpackage:
> error: dpkg-source -b pkg-grass gave error exit status 255 debuild:
> fatal error at line 1376: dpkg-buildpackage -rfakeroot -d -us -uc
> -S -sa failed gbp:error: 'debuild -S -sa' failed: it exited with
> 29
The core of the problem lies in invalid Debian packaging format
configuration, which is set to native in 'debian/source/format' which
can not contain Debian revision number in version (value you entered
in debian/changelog file). 'native' packages are only packages, which
are developed directly in Debian project, thus upstream is Debian and
no revision is needed. GRASS is not native one.
We should really move to Debian packaging done inside of DebianGIS [1]
for final 7.0 version (Sebastiaan from DebianGIS in CC). I can provide
some help for this.
As a quick solution for your problem, is to set package version in
debian/chagelog to something like 7.0.0~RC2-1 [2]
1 - http://anonscm.debian.org/cgit/pkg-grass/grass.git/log/?h=experimental
2 -
https://www.debian.org/doc/debian-policy/ch-controlfields.html#s-f-Version
Ivan Minčík
ivan.mincik at gmail.com GPG: 0x79529A1E
http://imincik.github.io/0x79529A1E.key
ivan.mincik at gista.sk GPG: 0xD714B02C
http://imincik.github.io/0xD714B02C.key
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJU2jbxAAoJEPfdLsR5Upoe9RAH/0ZAaqhy4Acm5GGkwr+D4kFX
ighxrB+DdnUq4W1SCWPRSnCzm6sXqJM/qswHNBvU6l7EqlZKfBFZy6ALKCCuogvX
E+Z6UkUZ8xbPlmD3bgAVQcdYthldYmVjrOjQdlKF1Bzl+WVzKEXNRGMNaj286hpk
8UuP70OsE/Ph+5MUP4nhb7c4We+/LnVKP8XtLkiHEeHA0binSMFM7TkoXyRgcAgD
H9uHxaXPDbeCOpnDSIYZyAtuQC7e4eTkCQLTEf0tpLN7hbVeabWr/PqBli3hJ7yk
DxShrM4Oo+GPihaK3QoUE8F9eEtpyVbNx+cEq1BGM6lIvKIJG5Iafl9kesk6iog=
=QNOA
-----END PGP SIGNATURE-----
