[GRASS-dev] [GRASS GIS] #2587: copying attribute tables very inefficient if tables are in same database
trac at osgeo.org
Wed Feb 11 10:18:31 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Database | Version: svn-trunk
Keywords: libdb copy table | Platform: Unspecified
Cpu: Unspecified |
The function copy_table in lib/db/dbmi_client/copy_tab.c seems very
inefficient to me when both the old and the new table are in the same
database and it is a database with real SQL functionalities. IIUC, the
function actually selects all rows from the input table into a cursor and
the inserts them, row by row, into the output table. With a large table
this takes a long time.
Using a simple "CREATE TABLE new_table AS SELECT [*, ListOfColumns] FROM
old_table WHERE [Conditions]" is much faster !
So, it would be a great addition if for the relevant drivers, such as
SQLite and PostgreSQL, could use this approach.
P.S. There is no LibDB component in the tracker. Don't know if there
should be...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2587>
