[GRASS-dev] [GRASS GIS] #2572: grass command welcomes batch job and requires user input
GRASS GIS trac at osgeo.org
Wed Feb 11 13:44:03 PST 2015
  Reporter:  wenzeslaus  |       Owner:  grass-dev@…
      Type:  defect      |      Status:  closed
  Priority:  minor       |   Milestone:  6.4.5
 Component:  Startup     |     Version:  6.4.4
Resolution:  fixed       |    Keywords:  GRASS_BATCH_JOB, rc file, init, startup
  Platform:  Linux       |         Cpu:  Unspecified
Changes (by wenzeslaus):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:1 wenzeslaus]:
 > r64408 should be safe enough to be backported any time to release branch
 but the right time is after RC2 considering the freeze.
 Backported to 7.0 in r64569 after RC2 and after test on MS Windows (with
 removed `GRASS7` in the `AppData` `Roaming` directory). I got to startup
 window so easily that I had to start beta3 too see what I'm actually
 testing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2572#comment:2>
