[GRASS-dev] [GRASS GIS] #2579: Specify command to be exectued as parameter of grass command
trac at osgeo.org
Wed Feb 11 15:03:42 PST 2015
Reporter: wenzeslaus | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.1.0
Component: Startup | Version: svn-trunk
Keywords: batch job, GRASS_BATCH_JOB, init | Platform: All
Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:1 mlennert]:
> Why do you need the --mapset as in:
grass7 --mapset ~/grassdata/location/mapset --batch r.mapcalc "aaa = 5"
> The current GRASS startupt script already allows to define a mapset at
startup, so this seems redundant.
This is a thing I'm not sure about. The current syntax is
grass ~/grassdata/nc_spm_08_grass7/user1
grass -c ~/grassdata/nc_spm_08_grass7/user1
which follows the following general pattern
name options/flags files
name [option]... [file]...
name [option]... [file] [arg]...
where options/flags are distinguished by `-` or `--` and first thing which
is not an option starts a file list. The last row actually describes
`python` and `Rscript`:
python [option] ... [-c cmd | -m mod | file | -] [arg] ...
Rscript [--options] [-e expr [-e expr2 ...] | file] [args]
So it seems that they actually leave out (equivalent of) `--batch`. If we
would allow not to specify db+l+mapset then one could use:
grass .../test_script.sh
grass r.info
grass r.mapcalc "aaa = 5"
which could be hard to distinguish from (current):
We can also say that db+l+mapset is always required when passing module or
script because the usual use case is when GRASS GIS is used as processing
backend and in this case you rarely want to use db+l+mapset from rc file.
This gives us:
grass ~/grassdata/nc_spm_08_grass7/user1 .../test_script.sh
grass ~/grassdata/nc_spm_08_grass7/user1 r.info
grass ~/grassdata/nc_spm_08_grass7/user1 r.mapcalc "aaa = 5"
In this case, I'm not sure how well we can distinguish different cases
(standard/batch) when parsing and how we can provide good error messages.
Similar, but not the same, case is `grep`. With `grep` you always have to
provide the `PATTERN` parameter:
grep [OPTION]... PATTERN [FILE]...
In our case all parameters would be optional. The order is really
important in this case and identification of options can become tricky,
although hopefully not as much as with `grep` (try to search for a string
which starts with `-`). If we decide for something like this, the command
line parsing in `grass.py` will have to be reimplemented, at least I think
according to the code. For example, you have to recognize where the actual
command starts because then everything else should not be used (trivial
with `--batch`, hard without).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2579#comment:2>
