[GRASS-dev] [GRASS-SVN] r64426 - grass/trunk/lib/python/script
Markus Neteler
neteler at osgeo.org
Wed Feb 11 15:50:44 PST 2015
should this be backported?
Markus
On Tue, Feb 3, 2015 at 4:20 PM, <svn_grass at osgeo.org> wrote:
> Author: glynn
> Date: 2015-02-03 07:20:48 -0800 (Tue, 03 Feb 2015)
> New Revision: 64426
> Modified:
> grass/trunk/lib/python/script/array.py
> Log:
> numpy.memmap() no longer has _close; use __del__ instead
> Modified: grass/trunk/lib/python/script/array.py
> --- grass/trunk/lib/python/script/array.py 2015-02-03 15:01:35 UTC (rev 64425)
> +++ grass/trunk/lib/python/script/array.py 2015-02-03 15:20:48 UTC (rev 64426)
> @@ -150,8 +150,7 @@
> self.filename = filename
> return self
> - def _close(self):
> - numpy.memmap._close(self)
> + def __del__(self):
> if isinstance(self, array):
> try_remove(self.filename)
> @@ -273,10 +272,8 @@
> return self
> - def _close(self):
> - if isinstance(self, array):
> + if isinstance(self, array3d):
> def read(self, mapname, null=None):
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
