[GRASS-dev] [GRASS GIS] #2588: wxGUI digitizer: error when adding a new column
trac at osgeo.org
Wed Feb 11 15:54:49 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-releasebranch70
Keywords: digitizer crash add column | Platform: Unspecified
Cpu: Unspecified |
- In wxGUI Display Manager, chose Digitize -> New map
- Try to add a new column to the new map:
ATTENTION: Unable to open vector map <test1 at user1> on level 2. Try to
rebuild vector topology with v.build.
ERREUR :Unable to open vector map <test1 at user1>
File "/data/home/mlennert/SRC/GRASS/grass-7.0.0RC2/dist.x86_64-unknown-
linux-gnu/scripts/v.db.addcolumn", line 88, in <module>
main()
linux-gnu/scripts/v.db.addcolumn", line 84, in main
grass.vector_history(map)
linux-gnu/etc/python/grass/script/vector.py", line 145, in vector_history
run_command('v.support', map=map, cmdhist=os.environ['CMDLINE'])
linux-gnu/etc/python/grass/script/core.py", line 375, in run_command
return handle_errors(returncode, returncode, args, kwargs)
linux-gnu/etc/python/grass/script/core.py", line 310, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['v.support',
'map=test1 at user1', 'cmdhist=v.db.addcolumn "--q" "map=test1 at user1"
"layer=1" "columns=tt1 integer"'] ended with error
Process ended with non-zero return code 1. See errors in the (error)
output.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2588>
