[GRASS-dev] Compute mahalanobis distance using Scipy
Paulo van Breugel p.vanbreugel at gmail.com
Fri Feb 13 01:40:55 PST 2015
On Fri, Feb 13, 2015 at 10:13 AM, Paulo van Breugel <p.vanbreugel at gmail.com>
wrote:
> Hi Pietro,
> Thanks for the suggestion, I will have a look at the documentation.
> Paulo
> On Fri, Feb 13, 2015 at 10:09 AM, Pietro <peter.zamb at gmail.com> wrote:
>> Dear Paulo,
>> On Fri, Feb 13, 2015 at 9:57 AM, Paulo van Breugel
>> <p.vanbreugel at gmail.com> wrote:
>> > I guess this is because the calculations are done in-memory? Any way to
>> > avoid this memory problem when using large data sets (something like
>> working
>> > with memmap objects?)
>> With memmap you still have a limits of 2Gb I guess, you should try: dask
Just reading the memmap manual page, where it reads: "Memory-mapped arrays
use the Python memory-map object which (prior to Python 2.5) does not allow
files to be larger than a certain size depending on the platform. This size
is always < 2GB even on 64-bit systems.". Which is unclear to me; I am not
sure if that means that this limit is different or does not apply when on
Python 2.5 or newer (what is the minimum python version for GRASS?)
>> Dask Array implements the NumPy ndarray interface using blocked
>> algorithms, cutting up the large array into many small arrays. This
>> lets us compute on arrays larger than memory using all of our cores.
>> We coordinate these blocked algorithms using dask graphs.
>> http://dask.readthedocs.org/en/latest/array.html
>> I didn't have a chance to try it yet, but it support a numpy array
>> syntax, and since you are using quite basic functionalities I think
>> you should be able to work with it.
>> All the best
>> Pietro
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150213/908c415d/attachment-0001.html>
