[GRASS-dev] [GRASS GIS] #2252: wxGUI vector digitizer passing unescaped text to database
GRASS GIS trac at osgeo.org
Fri Feb 13 11:40:31 PST 2015
 Reporter:  marisn                                                           |       Owner:  grass-dev@…
     Type:  defect                                                           |      Status:  new
 Priority:  critical                                                         |   Milestone:  7.0.0
Component:  wxGUI                                                            |     Version:  svn-trunk
 Keywords:  security, code injection, SQL injection, data loss, v.db.update  |    Platform:  Unspecified
      Cpu:  Unspecified                                                      |
Changes (by marisn):
  * priority:  blocker => critical
Comment:
 Replying to [comment:6 mlennert]:
 > Ok, I forgot the apostrophes.
 > However, I tried deleting a table and haven't been able to do so:
 > db.execute sql="CREATE TABLE test_db_bug (id int)"
 > v.db.update test_digit_new col=test_text val="';drop table
 test_db_bug;'"
 > Table test_db_bug is still in the database. Same when I put the same
 value in a text field in the digitizer: I get a similar error message to
 yours above, but the table is not dropped.
 > Apparently any apostrophe in the update value causes an error message. I
 agree that the error message is not clear, but I cannot reproduce the
 danger you see for database integrity.
 > So my question remains, is this really a blocker ?
 > Moritz
 OK, OK. I'm downgrading priority. My attempts to execute drop table
 somehow failed. I blame my poor SQL skills for it. Probably it is really
 just a "no apostrophes in attribute text" rule without any (so far
 confirmed) security issue.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2252#comment:7>
