[GRASS-dev] [GRASS GIS] #2028: SetVirtualSizeHints is deprecated in wxWidgets 2.9
GRASS GIS trac at osgeo.org
Sat Feb 14 14:57:49 PST 2015
 Reporter:  marisn                 |       Owner:  grass-dev@…
     Type:  defect                 |      Status:  new
 Priority:  minor                  |   Milestone:  7.0.0
Component:  wxGUI                  |     Version:  svn-trunk
 Keywords:  wxPython 3, FitInside  |    Platform:  Unspecified
      Cpu:  Unspecified            |
Changes (by wenzeslaus):
  * keywords:  => wxPython 3, FitInside
Comment:
 The only occurrences of this warning in trunk r64634 are:
 dbmgr/base.py:2895:        layerSizer.SetVirtualSizeHints(self.addPanel)
 gui_core/goutput.py:231:
 self.outputSizer.SetVirtualSizeHints)(self.panelOutput)
 where only the first one is an issue causing following output when dbmgr
 is started:
 .../gui/wxpython/dbmgr/base.py:2895: wxPyDeprecationWarning:
 Call to deprecated item 'SetVirtualSizeHints'.
 Using the following code from `gui_core/goutput.py`:
         # eliminate gtk_widget_size_allocate() warnings
         # avoid to use a deprecated method in wxPython >= 2.9
         getattr(self.outputSizer, 'FitInside',
 fixed in r64635 for trunk. This is very safe, but anyway I would backport
 it between 7.0.0 and 7.0.1 just to be sure. Close afterwards.
 No warning generated when starting dbmgr. Tested with wxPython 3.0
 (Lubuntu):
 GRASS version: 7.1.svn
 GRASS SVN revision: 64565M
 Build date: 2015-01-11
 Build platform: x86_64-unknown-linux-gnu
 GDAL: 1.10.1
 PROJ.4: 4.8.0
 GEOS: 3.4.2
 SQLite: 3.8.6
 Python: 2.7.8
 wxPython: 3.0.0.0
 Platform: Linux-3.16.0-30-generic-x86_64-with-Ubuntu-14.10-utopic
Ticket URL: <http://trac.osgeo.org/grass/ticket/2028#comment:1>
