[GRASS-dev] [GRASS GIS] #1576: r.in.poly broken by window split
trac at osgeo.org
Sat Feb 14 19:43:06 PST 2015
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Resolution: fixed | Keywords: r.in.poly, i.topo.corr, Rast_set_window(),
Platform: All | Cpu: All
Changes (by wenzeslaus):
* status: new => closed
* resolution: => fixed
Comment:
I don't get any error with the code posted and G7:r.in.poly changed quite
a bit. Closing the ticket as fixed. Reopen if you are still getting
`...Output window changed while...` and please submit
[http://grass.osgeo.org/grass71/manuals/libpython/gunittest_testing.html a
test] which shows it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1576#comment:8>
