[GRASS-dev] [GRASS GIS] #2583: v.net: crash on Windows
trac at osgeo.org
Sun Feb 15 01:37:45 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: LibVector | Version: svn-releasebranch70
Keywords: v.net | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:8 neteler]:
> Replying to [comment:7 annakrat]:
> > I just don't like releasing grass with a serious bug when we haven't
even tried to fix it.
> Well, it does not happen e.g. on Linux.
> > I am talking about postponing it max one week. Basically, my question
is: can Markus Metz look at it soon enough?
> No idea.
> > If not, then we can probably release it now.
> Changes I see after RC1:
> * r64200 diglib: add numerical stability to dig_test_for_intersection()
> * r64198 diglib: add numerical stability to
dig_distance2_point_to_line()
> * r64196 diglib: add numerical stability to dig_x_intersect()
> * many changes in
http://trac.osgeo.org/grass/log/grass/branches/releasebranch_7_0/lib/vector/Vlib
These also do not respect the proposed release procedure:
"Any commits from that point [RC] on can only be well-tested, non-invasive
bug fixes."
Many of these changes do not even seem to be bug fixes, but optimization.
Typically the stuff that should have been tested in trunk and if stable
integrated into the next point release...
And, yes, tests should help, but they also would have to be run on
different platforms before commits.
And my level of understanding does not allow me to understand what in
there might cause a MSWin-specific issue. My highest contender, in light
of Martin's debug info above is r64215.
Do I understand correctly that r64163 was just in time to be included into
RC1 ?
Martin, could you rerun your windows builds to get versions before and
after the above change, or is that too much work ?
Or maybe Glynn could have a look at these changes to see if there's
anything obvious to more informed eyes than mine ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2583#comment:17>
