[GRASS-dev] [GRASS GIS] #2583: v.net: crash on Windows
GRASS GIS trac at osgeo.org
Sun Feb 15 01:53:34 PST 2015
 Reporter:  mlennert     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  blocker      |   Milestone:  7.0.0
Component:  LibVector    |     Version:  svn-releasebranch70
 Keywords:  v.net        |    Platform:  MSWindows 8
      Cpu:  Unspecified  |
Comment(by marisn):
 On ~AMD64 Linux I don't see any crash but Valgrind is complaining about
 use of uninitialized values. Seems that there is a problem when vector is
 not a 3D one. Don't know it could be the source of a crash in the Windows
 version.
 Still in the light of recent Martin comments it could be the case.
 Markus - leak-check doesn't matter unless we are optimizing code. Lost
 memory is just wasted memory - it doesn't harm (except consuming few bytes
 of RAM).
 ==10082== Conditional jump or move depends on uninitialised value(s)
 ==10082==    at 0x5FBA939: dig_line_box (box.c:51)
 ==10082==    by 0x4E74AE2: V2__add_line_to_topo_nat (write_nat.c:895)
 ==10082==    by 0x4E752A4: V2_rewrite_line_nat (write_nat.c:228)
 ==10082==    by 0x4E51082: Vect_rewrite_line (write.c:231)
 ==10082==    by 0x405979: connect_arcs (connect.c:87)
 ==10082==    by 0x403164: main (main.c:146)
 ==10082==  Uninitialised value was created by a stack allocation
 ==10082==    at 0x405550: connect_arcs (connect.c:23)
 ==10082==
 ==10082==    at 0x4E63D63: Vect_box_extend (box.c:126)
 ==10082==    by 0x4E74B47: V2__add_line_to_topo_nat (write_nat.c:908)
 ==10082==
 ==10082==    by 0x4E75161: V2_write_line_nat (write_nat.c:80)
 ==10082==    by 0x4E50FA3: Vect_write_line (write.c:189)
 ==10082==    by 0x405856: connect_arcs (connect.c:99)
 ==10082==
 ==10082==    at 0x5FBA944: dig_line_box (box.c:53)
 ==10082==
 ==10082==
 ==10082==    at 0x5FBA8D8: dig_line_box (box.c:51)
 ==10082==    by 0x405A1B: connect_arcs (connect.c:122)
 ==10082==
 ==10082==
 ==10082==    at 0x4E68F68: Vect_line_prune (line.c:290)
 ==10082==    by 0x40582E: connect_arcs (connect.c:96)
 ==10082==
 ==10082==    at 0x4E68F6A: Vect_line_prune (line.c:290)
 ==10082==
 ==10082==    by 0x40579A: connect_arcs (connect.c:85)
 ==10082==
Ticket URL: <http://trac.osgeo.org/grass/ticket/2583#comment:20>
