[GRASS-dev] Howto use a Python function as error handler in libgis
Sören Gebbert
soerengebbert at googlemail.com
Sun Feb 15 15:13:26 PST 2015
Hi Glynn,
thanks a lot, that solved the issue.
Best regards
Soeren
2015-02-14 4:10 GMT+01:00 Glynn Clements <glynn at gclements.plus.com>:
> Sören Gebbert wrote:
>> Dear developers,
>> i am trying to register a Python function as error handler callback
>> using ctypes in libgis.
>> I use this code in the temporal framework:
>> def error_handler(data):
>> pass
>> CALLBACK = CFUNCTYPE(None, c_void_p)
> AFAICT, this needs to be:
> CALLBACK = CFUNCTYPE(c_void_p, c_void_p)
> For callbacks, ctypesgen converts any return type which isn't a
> primitive C type to c_void_p. And None isn't a primitive C type.
