[GRASS-dev] [GRASS GIS] #2583: v.net: crash on Windows
trac at osgeo.org
Mon Feb 16 08:38:25 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: LibVector | Version: svn-releasebranch70
Keywords: v.net | Platform: MSWindows 8
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:23 mmetz]:
> > more precisely it's somewhere here:
source:grass/trunk/lib/vector/Vlib/write.c#L231. In my case before calling
rewrite fn from array `points = 04033a60`, inside `V2_rewrite_line_nat()`
it's lost `points = 00000002`.
> The bug was differing function parameter types in the fn arrays, causing
memory corruption. Fixed in trunk r64644, tested on MS Windows and Linux.
I will backport the fix if the nightly build of trunk works by tomorrow.
I have created extra builds (no. 1225), and tested G71. It seems to be
fixed. Thanks! Could you backport it today?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2583#comment:24>
