[GRASS-dev] Problems using pygrass' Region()
Paulo van Breugel p.vanbreugel at gmail.com
Mon Feb 16 11:12:12 PST 2015
I am trying to repeatedly change the region in a script. To get the current
region I would normally use
>>>reg1 = grass.script.region()
When using pygrass, I can also use
>>>import grass.pygrass.gis.region as region
>>>reg2 = region.Region()
The first time I run this reg1 = reg2
Now, when I change the region, and run again:
>>>reg3 = grass.script.region()
The reg3 values reflect the new region settings. However, when I run
The reg4 values are the same as reg2
How do I get a Region object with the current / changed region settings?
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150216/61fada45/attachment.html>
