[GRASS-dev] [GRASS GIS] #2583: v.net: crash on Windows
trac at osgeo.org
Tue Feb 17 06:12:41 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: closed
Priority: blocker | Milestone: 7.0.0
Component: LibVector | Version: svn-releasebranch70
Resolution: fixed | Keywords: v.net
Platform: MSWindows 8 | Cpu: Unspecified
Comment(by wenzeslaus):
The test for v.net is now at 50%. This is a little bit suspicious. The
values changed from yesterday before the last fixes (r64644, r64656). Test
suite for v.net was added in r64639 and the values were obtained before
the last fixes which can mean that r64644 or r64656 changed the results.
Which results are the right ones? Is this even expected?
Test results:
[http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-02-16-08-00/report_for_nc_spm_08_grass7_nc/vector/v.net/test_v_net/index.html
v.net test for r64642]
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-02-17-08-00/report_for_nc_spm_08_grass7_nc/vector/v.net/test_v_net/index.html
v.net test for r64658]
Current test output:
FAIL: test_connect (__main__.TestVNet)
Test
File "vector/v.net/testsuite/test_v_net.py", line 36, in test_connect
self.assertVectorFitsTopoInfo(vector=self.network, reference=topology)
File "etc/python/grass/gunittest/case.py", line 309, in
precision=0)
File "etc/python/grass/gunittest/case.py", line 202, in
assertModuleKeyValue
self.fail(self._formatMessage(msg, stdMsg))
AssertionError: v.info map=test_vnet layer=1 -t difference:
mismatch values (key, reference, actual): [('lines', 50080, 50069)]
command: v.info map=test_vnet layer=1 -t {'map': 'test_vnet', 'flags':
't'}
FAIL: test_connect_snap (__main__.TestVNet)
Test
File "vector/v.net/testsuite/test_v_net.py", line 45, in
test_connect_snap
precision=0)
mismatch values (key, reference, actual): [('lines', 49913, 49902)]
't'}
I'm getting the same results locally as on the test server.
To test yourself:
# start GRASS session in nc_smp_08_grass7 Location and then
cd vector/v.net/testsuite
python test_v_net.py
For more complex output:
# start GRASS session in any Location and then
python -m grass.gunittest.main --location nc_smp_08_grass7 --location-type
nc
Ticket URL: <http://trac.osgeo.org/grass/ticket/2583#comment:29>
