[GRASS-dev] [GRASS GIS] #2561: 7.0.0 beta & RC tarballs contain precompiled Python objects
trac at osgeo.org
Tue Feb 17 13:01:44 PST 2015
Reporter: sebastic | Owner: grass-dev@…
Type: defect | Status: closed
Priority: blocker | Milestone: 7.0.0
Component: Packaging | Version: svn-releasebranch70
Resolution: fixed | Keywords: python, pyc
Platform: All | Cpu: Unspecified
Changes (by wenzeslaus):
* keywords: python => python, pyc
Comment:
Replying to [comment:7 cmbarton]:
> FWIW, I am still getting errors during compilation of 7.0 release branch
for the following:
I believe you meant to post it to #1819.
Also here are some tips on using Trac Tickets: To insert things verbatim,
use `{{{` and `}}}` on separate lines before and after the verbatim text.
This is especially advantageous for program outputs where you want to safe
newlines and other whitespace. See WikiFormatting linked above the input
box for more options. To ensure that it is working as you intended, you
can use ''Preview'' button at the bottom.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2561#comment:8>
