[GRASS-dev] [GRASS GIS] #2583: v.net: crash on Windows
trac at osgeo.org
Tue Feb 17 14:12:05 PST 2015
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: closed
Priority: critical | Milestone: 7.0.0
Component: LibVector | Version: svn-releasebranch70
Resolution: fixed | Keywords: v.net
Platform: MSWindows 8 | Cpu: Unspecified
Changes (by annakrat):
* status: reopened => closed
* resolution: => fixed
Comment:
Replying to [comment:32 mmetz]:
> Replying to [comment:30 mlennert]:
> > Replying to [comment:29 wenzeslaus]:
> > > The test for v.net is now at 50%. This is a little bit suspicious.
The values changed from yesterday before the last fixes (r64644, r64656).
Test suite for v.net was added in r64639 and the values were obtained
before the last fixes which can mean that r64644 or r64656 changed the
results. Which results are the right ones? Is this even expected?
> > MarkusM is the only one who can tell for sure, but I would not be
surprised that changes in topology handling induce changes in primitive
counts.
> The difference is caused by the fix for the uninitialized values in
`v.net`, therefore I am sure that the new result is correct. Uninitialized
double values (here: z coordinates) can have weird effects, I noticed that
earlier somewhere else. Unfortunately, this bug has been present in
`v.net` since GRASS 6.4.0 or earlier.
OK, I updated the test with the new values.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2583#comment:33>
