[GRASS-dev] [GRASS GIS] #1819: problems compiling map swipe, animation, modeler, and r.li.setup
GRASS GIS trac at osgeo.org
Tue Feb 17 20:29:25 PST 2015
 Reporter:  cmbarton         |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  7.0.0
Component:  wxGUI            |     Version:  svn-trunk
 Keywords:  g.gui.* modules  |    Platform:  MacOSX
      Cpu:  OSX/Intel        |
Comment(by wenzeslaus):
 Replying to [comment:12 wenzeslaus]:
 > That's the part which should be fixed once #2142 is fixed.
 Unfortunately, I'm not able to fix it for the 7.0.0 release. It requires a
 lot of design decisions and testing.
 A quick fix implemented in r64677. It is far from solving #2142 and it is
 quite dirty but it could solve (workaround) the compilation issue with wx,
 32/64 bit and toolboxes.
 > And as I said, these changes make sense in general but basically they
 are all workarounds. The actual issue is wrong runtime environment during
 compilation where 64 and 32 bit libraries are mixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1819#comment:13>
