[GRASS-dev] [GRASS GIS] #2591: error in grass.sh selecting python version
trac at osgeo.org
Thu Feb 19 05:42:09 PST 2015
Reporter: foret37 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: OSX/Intel |
I am running Grass 7.0.0RC1 on a Mac OSX 10.10.2. I launched the program
using the Grass app, and it failed with an error.
I then ran the script directly in the term, in order to see the error.
> cd /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/
> ./grass.sh
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.7.9 found.
arch: posix_spawnp: /opt/local/bin/pythonw2.7: Bad CPU type in executable
This problem is well known, and has to do with the selection of the wrong
version of python, as discussed at
http://grasswiki.osgeo.org/wiki/MacOSX_GRASS_errors.
Some sluthing showed that grass.sh selects a link in my MacPorts
directory, /opt/local/bin, that points to the native Apple version of
python.
I followed the instructions at MacOSX_GRASS_errors and added the following
environment variables:
export GRASS_PYTHON=/usr/bin/python2.6
export GRASS_PYTHONWX=/usr/bin/pythonw2.6
but that did not fix the problem (same errors).
After a lot of messing around, I found that I can get grass started by
placing the directory with the right version of python as first in the
path string:
export PATH="/usr/bin:$PATH"
Grass launches now, regardless of the status of the GRASS_PYTHON and
GRASS_PYTHONWX variables.
My casual reading of the grass.sh script suggests that it never checks
GRASS_PYTHONWX to see if it has a value.
That issue suggests that the solution to the problem is add a check for
GRASS_PYTHONWX.
One other issue that seems odd: Grass does not remember my initial
settings. In other words, each time I login, it goes through the questions
for a new user.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2591>
