[GRASS-dev] [GRASS GIS] #1819: problems compiling map swipe, animation, modeler, and r.li.setup
trac at osgeo.org
Thu Feb 19 15:26:27 PST 2015
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: g.gui.* modules | Platform: MacOSX
Cpu: OSX/Intel |
Comment(by cmbarton):
Replying to [comment:12 wenzeslaus]:
> Replying to [comment:10 cmbarton]:
> > This solved all the compiler errors except for g.gui.tplot
> I simply forgot to change `g.gui.tplot` because I was looking at the
list in comment:7:ticket:2561. Fixed in r64674.
> > and the failure to make the menu tree xml files.
> Replying to [comment:11 cmbarton]:
> > Because of the failure for some Python code to create the menu tree
files during compilation, I have to launch a GRASS session, cd to the
../gui/wxpython directory, make clean, and make. This also 'fixed' the
errors in animation, map swipe, etc.
> That's the part which should be fixed once #2142 is fixed.
Unfortunately, I'm not able to fix it for the 7.0.0 release. It requires a
lot of design decisions and testing.
> And as I said, these changes make sense in general but basically they
are all workarounds. The actual issue is wrong runtime environment during
compilation where 64 and 32 bit libraries are mixed.
> This ticket should be closed once r64664 and r64674 are backported to
release branch 7.0.
The compiling errors for mapswipe, etc (including tplot) are all now
fixed. The automatic menu building is not fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1819#comment:16>
