[GRASS-dev] problem in ubuntu package (ppa:grass-devel) was: can not install addons with g.extension
Robert Nuske
rnuske at gwdg.de
Fri Feb 20 08:29:27 PST 2015
Am Freitag, 20. Februar 2015, 08:32:17 schrieb Anna Petrášová:
> On Tue, Feb 17, 2015 at 9:41 AM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > On Tue, Feb 17, 2015 at 6:03 AM, Robert Nuske <rnuske at gwdg.de> wrote:
> >> Hi
> >> g.extension from grass70 (ppa:grass-devel) still fails.
> >> Traceback (most recent call last):
> >> File "/usr/lib/grass70/tools/g.html2man.py", line 5, in <module>
> >> from html import HTMLParser, HTMLParseError
> >> ImportError: No module named html
> >> GRASS Version: 7.0.0+1svn64647~ubuntu14.04.1
> >> package from PPA grass-devel
> >> ubuntu 14.04 64bit
> >> Not getting anywhere with that error message, I build GRASS
> >> releasebranch_7_0
> >> from source according to
> >> http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu#GRASS_GIS
> >> Everything works nicely, including g.extension
> >> Installation of <r.grow.shrink> successfully finished
> >> Starting the packaged version of GRASS 7 afterwards (/usr/bin/grass70)
> >> leads to errors and no wxpython GUI.
> >> Error message in popup window:
> >> Unable to parse user toolboxes XML files. Default module tree will be
> >> loaded.
> >> Ursache: 'ascii' codec can't encode character u'\xfc' in position 201:
> >> ordinal
> >> not in range(128)
> >> File "/usr/lib/grass70/gui/wxpython/lmgr/menudata.py", line 62, in
> >> __init__
> >> MenuTreeModelBuilder.__init__(self, filename,
> >> expandAddons=expandAddons)
> >> File "/usr/lib/grass70/gui/wxpython/core/menutree.py", line 66, in
> >> __init__
> >> expAddons(xmlTree)
> >> File "/usr/lib/grass70/gui/wxpython/core/toolboxes.py", line 280, in
> >> expandAddons
> >> _expandRuntimeModules(root, loadMetadata=True)
> >> File "/usr/lib/grass70/gui/wxpython/core/toolboxes.py", line 525, in
> >> desc, keywords = _loadMetadata(name)
> >> File "/usr/lib/grass70/gui/wxpython/core/toolboxes.py", line 560, in
> >> _loadMetadata
> >> sys.stderr.write("%s: %s\n" % (module, e))
> >> File "/usr/lib/grass70/etc/python/grass/exceptions/__init__.py", line
> >> 48, in
> >> __str__
> >> return str(self.value)
> >> UnicodeEncodeError: 'ascii' codec can't encode character u'\xfc' in
> >> position
> >> 201: ordinal not in range(128)
> > Hi,
> > I tried to fix it in r64661 in trunk. I assume the problem is that the
> > error message is translatable and has some non-ascii characters. Could
> > anyone test it in trunk (preferably with different locale)? Any better
> > solution is welcome too. We should fix this before the release.
> Could anyone test it? I think this should be backported since the bug
> prevents from starting gui but I need someone with different locale to test
> it. I think the error message contains non-ascii characters which is the
> problem then. Sorry I forgot about this in the last days and nobody else
> really paid attention to this one. Or we can completely skip loading
> metadata addon modules for the release as it is now on Windows. Any opinion?
- compiled grass trunk from source
(couldn't find a way to come by sensible version information within grass)
grass7_trunk$ svnversion
64696
- started grass_trunk
GRASS 7.0.0 (test_location):~ > locale
LANG=de_DE.UTF-8
LANGUAGE=de:en_US:en_GB:en
LC_CTYPE="de_DE.UTF-8"
GRASS 7.0.0 (test_location):~ > g.extension r.grow.shrink --verbose
Updating metadata file...
Manual page for <r.grow.shrink> updated
Afterwards GRASS trunk (64696) and current releasebranch (64695, todays ubuntu
package, thanks to Martin L) start fine.
None of the above problems persist!
cheers,
robert
