[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
GRASS GIS trac at osgeo.org
Sat Feb 21 00:49:31 PST 2015
  Reporter:  martinl      |       Owner:  grass-dev@…
      Type:  task         |      Status:  closed
  Priority:  blocker      |   Milestone:  7.0.0
 Component:  Default      |     Version:  unspecified
Resolution:  fixed        |    Keywords:  standardized options
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by martinl):
 Replying to [comment:199 glynn]:
 > Replying to [comment:195 wenzeslaus]:
 > > I have very limited QGIS Processing knowledge but I guess QGIS
 Processing still needs `r.mapcalculator` because there is not way how QGIS
 Processing can know which maps to import and which maps to export. From my
 understanding, the only way to know would be if standard `r.mapcalc` would
 offer a flag (e.g. `-l`) which lists the inputs and output(s?):
 > Such an option would be fairly simple to add. Most of the relevant logic
 is already present in execute() in r.mapcalc/evaluate.c.
 > The initialize() function populates the list of input maps (in
 r.mapcalc/map.c or map3.c), which can be used to generate the list of
 inputs. Each top-level assignment expression defines an output.
 reported as #2592
Ticket URL: <http://trac.osgeo.org/grass/ticket/2409#comment:201>
