[GRASS-dev] Non-linear (multiple) regression in GRASS?
Pietro peter.zamb at gmail.com
Sat Feb 21 06:21:23 PST 2015
Hi Nikos,
On Sat, Feb 21, 2015 at 2:08 PM, Nikos Alexandris
<nik at nikosalexandris.net> wrote:
> and advanced users.  Has anyone perforned, or has plans to implement,
> non-linear (multi-) regression in GRASS  (not through R, of course)?
I did a pixel by pixel regression using most of the code of the
v.class.ml module, but the approach still need to act manually.
So it is not ready...
During next spring I would like to make a bit of order on the
v.class.ml module, maybe change also the name, to allow supervised,
unsupervised and regression tasks through scikit-learn library. If you
have some ideas on how would you like to organized these
module/modules, like: which inputs are required, the outputs, the
optional options and steps, please share them and we can start to
discuss on how implement what.
Best regards.
Pietro
