[GRASS-dev] [GRASS GIS] #2594: r.univar output error
GRASS GIS trac at osgeo.org
Sun Feb 22 21:11:41 PST 2015
 Reporter:  richardc                   |       Owner:  grass-dev@…
     Type:  defect                     |      Status:  new
 Priority:  normal                     |   Milestone:  7.0.1
Component:  Raster                     |     Version:  svn-releasebranch70
 Keywords:  r.univar statistics zones  |    Platform:  Linux
      Cpu:  x86-32                     |
 There appears to be an error in the output of r.univar when -g and -t
 options are NOT used. It looks like a formatting error, where there is a
 mismatch between categories reported in r.univar and the actual category
 in the zone file. E.g. category 2 reported by r.univar is derived from
 category 1 of the zones file.
 Example of output with -g and -t options:
 r.univar -g -t map=cahpa_i0apr_05216_nc_remapped_nc_1 at prcp05216ijk
 zones=BMR_bndry_epsg4326_rasterized at prcp05216ijk
 zone|label|non_null_cells|null_cells|min|max|range|mean|mean_of_abs|stddev|variance|coeff_var|sum|sum_abs
 1|Category
 1|2|0|3.58209799742326e-05|6.23035812168382e-05|2.64826012426056e-05|4.90622805955354e-05|4.90622805955354e-05|1.32413006213028e-05|1.75332042143714e-10|26.9887589010849|9.81245611910708e-05|9.81245611910708e-05
 2|Category
 2|1|0|3.53023679053877e-05|3.53023679053877e-05|0|3.53023679053877e-05|3.53023679053877e-05|0|0|0|3.53023679053877e-05|3.53023679053877e-05
 3|Category
 3|2|0|5.02148177474737e-05|8.14341983641498e-05|3.12193806166761e-05|6.58245080558117e-05|6.58245080558117e-05|1.5609690308338e-05|2.43662431522222e-10|23.7141009775611|0.000131649016111623|0.000131649016111623
 4|Category
 4|3|0|4.46328085672576e-05|8.2188387750648e-05|3.75555791833904e-05|6.12175620820684e-05|6.12175620820684e-05|1.56425403660131e-05|2.4468906910235e-10|25.552373916888|0.000183652686246205|0.000183652686246205
 5|Category
 5|3|0|3.81464305974077e-05|6.24195599812083e-05|2.42731293838006e-05|4.99398726484893e-05|4.99398726484893e-05|9.92133734132678e-06|9.8432934640405e-11|19.8665651615892|0.000149819617945468|0.000149819617945468
 6|Category
 6|2|0|1.89598704309901e-05|7.74326545069925e-05|5.84727840760024e-05|4.81962624689913e-05|4.81962624689913e-05|2.92363920380012e-05|8.54766619399701e-10|60.6611188093919|9.63925249379827e-05|9.63925249379827e-05
 Example without -t and -g options:
 r.univar map=cahpa_i0apr_05216_nc_remapped_nc_1 at prcp05216ijk
 zone 1 Category 1
 total null and non-null cells: 2
 total null cells: 0
 Of the non-null cells:
 n: 2
 minimum: 3.5821e-05
 maximum: 6.23036e-05
 range: 2.64826e-05
 mean: 4.90623e-05
 mean of absolute values: 4.90623e-05
 standard deviation: 1.32413e-05
 variance: 1.75332e-10
 variation coefficient: 26.9888 %
 sum: 9.81245611910708e-05
 zone 2 Category 2
 total null and non-null cells: 1
 total null cells: 0
 n: 1
 minimum: 3.53024e-05
 maximum: 3.53024e-05
 range: 0
 mean: 3.53024e-05
 mean of absolute values: 3.53024e-05
 standard deviation: 0
 variance: 0
 variation coefficient: 0 %
 sum: 3.53023679053877e-05
 zone 3 Category 3
 total null cells: 0
 n: 2
 minimum: 5.02148e-05
 maximum: 8.14342e-05
 range: 3.12194e-05
 mean: 6.58245e-05
 mean of absolute values: 6.58245e-05
 standard deviation: 1.56097e-05
 variance: 2.43662e-10
 variation coefficient: 23.7141 %
 sum: 0.000131649016111623
 zone 4 Category 4
 total null and non-null cells: 3
 total null cells: 0
 n: 3
 minimum: 4.46328e-05
 maximum: 8.21884e-05
 range: 3.75556e-05
 mean: 6.12176e-05
 mean of absolute values: 6.12176e-05
 standard deviation: 1.56425e-05
 variance: 2.44689e-10
 variation coefficient: 25.5524 %
 sum: 0.000183652686246205
 zone 5 Category 5
 total null cells: 0
 n: 3
 minimum: 3.81464e-05
 maximum: 6.24196e-05
 range: 2.42731e-05
 mean: 4.99399e-05
 mean of absolute values: 4.99399e-05
 standard deviation: 9.92134e-06
 variance: 9.84329e-11
 variation coefficient: 19.8666 %
 sum: 0.000149819617945468
 zone 6 Category 6
 total null cells: 0
 n: 2
 minimum: 1.89599e-05
 maximum: 7.74327e-05
 range: 5.84728e-05
 mean: 4.81963e-05
 mean of absolute values: 4.81963e-05
 standard deviation: 2.92364e-05
 variance: 8.54767e-10
 variation coefficient: 60.6611 %
 sum: 9.63925249379827e-05
 GRASS version: 7.0.0svn
 GRASS SVN Revision: 64042
 Build Date: 2015-01-10
 Build Platform: i686-pc-linux-gnu
 GDAL/OGR: 1.11.1
 PROJ.4: 4.9.0
 GEOS: 3.4.2
 SQLite: 3.7.9
 Python: 2.7.3
 wxPython: 2.8.12.1
 Platform: Linux-3.2.0-31-generic-pae-i686-with-LinuxMint-13-maya
Ticket URL: <https://trac.osgeo.org/grass/ticket/2594>
