[GRASS-dev] [GRASS GIS] #2460: v.out.postgis doesn't export attribute table
trac at osgeo.org
Mon Feb 23 05:30:03 PST 2015
Reporter: martin | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: svn-trunk
Keywords: v.out.postgis | Platform: Linux
Cpu: x86-64 |
Comment(by mlennert):
This seems to be linked to the handling of feature types:
v.out.postgis in=censusblk_swwake output='PG:dbname=nc_grass' --o
gives me the full attribute table, while
v.out.postgis in=censusblk_swwake type=area output='PG:dbname=nc_grass'
--o
only gives me fid, cat and geom columns.
BTW, when I try
v.out.postgis in=censusblk_swwake type=centroid
I get
ATTENTION: Unsupported geometry type (8)
ATTENTION: Unable to write feature in vector map <censusblk_swwake>
ERREUR :Feature type 8 is not supported
Erreur de segmentation
Ticket URL: <https://trac.osgeo.org/grass/ticket/2460#comment:3>
