[GRASS-dev] [GRASS GIS] #2595: Extend r.out.file to PNG/PS monitors
GRASS GIS trac at osgeo.org
Mon Feb 23 10:14:30 PST 2015
 Reporter:  gisix                      |       Owner:  grass-dev@…
     Type:  enhancement                |      Status:  new
 Priority:  normal                     |   Milestone:  7.1.0
Component:  Display                    |     Version:  unspecified
 Keywords:  r.out.file, d.save, d.mon  |    Platform:  Unspecified
      Cpu:  Unspecified                |
Changes (by wenzeslaus):
  * keywords:  r.out.file => r.out.file, d.save, d.mon
  * milestone:  7.0.1 => 7.1.0
Comment:
 Please, share the exact workflow and commands you are using or wish to
 use, so it is clear what you miss and what is your use case (which current
 system does not cover). Also, please test your workflow in both 6.4 and
 7.0 and be specific about what works and what does not work in each of
 them. Ideally provide a simple shell script (minimal working example)
 which shows the requested functionality.
 This looks like a feature which should be implemented for next version, so
 changing milestone.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2595#comment:6>
