[GRASS-dev] [GRASS GIS] #2596: v.rast.stats not working on GRASS 6.4.4
GRASS GIS trac at osgeo.org
Tue Feb 24 00:35:05 PST 2015
 Reporter:  micha          |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  major          |   Milestone:
Component:  Shell Scripts  |     Version:  6.4.4
 Keywords:                 |    Platform:  Linux
      Cpu:  Unspecified    |
 Using v.rast.stats in GRASS 6.4.4 I am finding two problems.
 The new script uses 'BEGIN TRANSACTION', but if the backend database is
 still dbf, transactions are not supported, and the process fails.
 If I switch to sqlite tables, the process runs, but I am getting NULL
 values in all the univariate stats columns.
 I tried to replace the v.rast.stats shell script with the script from the
 older 6.4.2 tarball, and it works fine.
 Regards,
 Micha
Ticket URL: <http://trac.osgeo.org/grass/ticket/2596>
