[GRASS-dev] Non-linear (multiple) regression in GRASS?
Nikos Alexandris nik at nikosalexandris.net
Tue Feb 24 06:36:42 PST 2015
Nikos Alexandris:
>> Hi devs,
>> and advanced users.  Has anyone performed, or has plans to
>> implement,
>> non-linear (multi-) regression in GRASS  (not through R, of course)?
Markus Metz:
> If it is raster based, you can use r.regression.multi to perform
> non-linear (multi-) regression in GRASS. It depends on what you mean
> with non-linear. E.g. if you want to perform a second-order multiple
> regression with 2 predictors, the formula is in R syntax
> y ~ x1 + x2 + x1 * x2 + x1 * x1 + x2 * x2
> You can calculate the terms x1 * x2, x1 * x1, x2 * x2 with r.mapcalc
> and feed everything to r.regression.multi.
> logarithmic:
> y ~ log(x1)
> r.mapcalc "logx1 = log(x1)"
> exponential:
> y ~ exp(x1)
> r.mapcalc "expx1 = exp(x1)"
> A combination of say a 4th-order polynomial with exponential
> components and 10 predictors could be constructed accordingly.
Speechless. Nikos
