[GRASS-dev] Non-linear (multiple) regression in GRASS?
Paulo van Breugel p.vanbreugel at gmail.com
Tue Feb 24 08:30:46 PST 2015
On Tue, Feb 24, 2015 at 3:31 PM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> Nikos Alexandris:
>  and advanced users.  Has anyone performed, or has plans to implement,
>>> non-linear (multi-) regression in GRASS  (not through R, of course)?
> Pietro:
>  I did a pixel by pixel regression using most of the code of the
>> v.class.ml module, but the approach still need to act manually.
>> So it is not ready...
>  During next spring I would like to make a bit of order on the
>> v.class.ml module, maybe change also the name, to allow supervised,
>> unsupervised and regression tasks through scikit-learn library. If you
>> have some ideas on how would you like to organized these
>> module/modules, like: which inputs are required, the outputs, the
>> optional options and steps, please share them and we can start to
>> discuss on how implement what.
> Pietro,
> thanks for chiming-in.  I need an approach for raster images, as (usual,
> perfectly) explained by Markus M.  I think, it's exactly what I am in need
> for.
I wonder if it is possible to utilize the scikit-learn library for rasters
as well.. The library offers a broad range of regression models, as well as
clustering and classification functions.
> Nikos
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20150224/38c80226/attachment.html>
